fromtimestamp
Mar 20, 2023Aspirant
Can MR6450 be connected to 5G SA?
Can MR6450 be connected to 5G SA? I'm in China. I bought Mr5200 before. I couldn't get the SA update for a long time, so I had to give up this machine. By the way, has Mr5200 supported 5G SA so far?
JohnPeng
Mar 20, 2023NETGEAR Expert
MR6450 supports SA. The following band are enabled for SA.
No plan to enabled SA on MR5200.
Thanks
fromtimestamp
Does it support sa for n78 n1/3/28?Much thanks
- fromtimestampMar 20, 2023AspirantDoes it support sa for n78 n1/3/28?Much thanks I don't see which frequency bands support sa. Can you send it again? JohnPeng
- JohnPengMar 20, 2023NETGEAR Expert
The following NR bands are supported for SA.
n1,n2,n3,n5,n7,n8,n20,n28,n40,n41,n71,n77,n78
- fromtimestampMar 21, 2023Aspirant
Thank you very much. In addition, I also want to know whether mr6500-1TLAUS supports SA in N78? If SA is not enabled for the time being, when will it support SA in N78? JohnPeng
