fromtimestamp
Mar 20, 2023Aspirant
Can MR6450 be connected to 5G SA?
Can MR6450 be connected to 5G SA? I'm in China. I bought Mr5200 before. I couldn't get the SA update for a long time, so I had to give up this machine. By the way, has Mr5200 supported 5G SA so far?
fromtimestamp
Does it support sa for n78 n1/3/28?Much thanks
fromtimestamp
Does it support sa for n78 n1/3/28?Much thanks I don't see which frequency bands support sa. Can you send it again? JohnPeng
- JohnPengMar 20, 2023NETGEAR Expert
The following NR bands are supported for SA.
n1,n2,n3,n5,n7,n8,n20,n28,n40,n41,n71,n77,n78
- fromtimestampMar 21, 2023Aspirant
Thank you very much. In addition, I also want to know whether mr6500-1TLAUS supports SA in N78? If SA is not enabled for the time being, when will it support SA in N78? JohnPeng
