v1elvet
Dec 17, 2023Aspirant
Can MS 60 satellites be used with MR 90 Nighthawk router?
The ethernet port on my MR60 stopped working, so I've upgraded to the MK93. Everything is working fine, but I was wondering if the old equipment could be put to use. I tried pairing the MS 60 satellites through the app, but the app reported that no additional satellite was found.
The old system put out a strong Wi-Fi signal, but I needed the wire to my switches.
Does anyone know if i can get the old satellites to work with the new router for more coverage?
1 Reply
This message in the wrong section and looks suspiciously like this conversation (which is also in a wrong section:
Can MS 60 satellites be used with MR 90 Nighthawk ... - NETGEAR Communities
Proceed with caution.
