BoyscoutYang
Aug 15, 2019Aspirant
Can not access either the Nighthawk mobile app or web browser.
Just purchased a unlocked nighthawk M1 router Telstra version from taobao. I am in Taiwan using the Tstar telecom (formerly known as Vibo). Firstly I can access the setting up pages from either 'th...
- Mar 07, 2020
Thank for your reply.
I have solved this problem already.
The reason for my problem is because the old firmware of T1 can not recognize my Tstar telecom.
So I use other sim card to upgrade the firmware of T1 and then it can recognize my Tstar telecom.
BoyscoutYang
Sep 11, 2019Aspirant
Is there any solution available?
M1 MR1100 (with "T")
Thanks a lot!
RedRaspberry
Mar 07, 2020Guide
This just happened to me and I had to do a factory reset, re-eneter the unlock code and then put in the new SIM.
- BoyscoutYangMar 07, 2020Aspirant
