BoyscoutYang's avatar
BoyscoutYang
Can not access either the Nighthawk mobile app or web browser.
Just purchased a unlocked nighthawk M1 router Telstra version from taobao. I am in Taiwan using the Tstar telecom (formerly known as Vibo). Firstly I can access the setting up pages from either 'th...
  • BoyscoutYang's avatar
    BoyscoutYang
    Mar 07, 2020
    Thank for your reply.
    I have solved this problem already.
    The reason for my problem is because the old firmware of T1 can not recognize my Tstar telecom.
    So I use other sim card to upgrade the firmware of T1 and then it can recognize my Tstar telecom.
