krusty99
Feb 03, 2023Follower
Can not Maintaining connection with HP110 desktop via cable.
Router Model LAX20. internet keeps dropping out every few seconds. any suggestions please.
Not sure if problem is router or desktop.
1 Reply
Has that got anything to do with the subject of this message?
What is it that keeps dropping? Wi-Fi? Internet? Printer?
The LAX20 is not one of the Nighthawk Wi-Fi 5 (AC) Routers covered in this section.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section. For a start they depend on which mobile network you are on.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
