rvtips's avatar
rvtips
Guide
Mar 23, 2026
can not see my net worth on my M6 Pro
I have been using my MR1100 for a long time with no problems but I was told the  M6 Pro is much better. So I got one.
I connected it to my desktop,phone and TV But When I search for my net worth on my dell lap top it is not there ?
It did work when I was using the MR1100.
I need this to work because I use the lap top when we are in the motorhome.
Phil
  • It sounds like a device/network configuration issue rather than the router itself. The M6 Pro sometimes handles connected devices differently compared to the MR1100, especially in how it assigns network visibility across devices.
    A few things you can try:
    Restart both the router and your laptop
    Forget and reconnect the WiFi network on the laptop
    Check if the laptop is on the same network band (2.4GHz vs 5GHz)
    Disable any VPN or firewall temporarily to test
    Make sure the router firmware is up to date
    Also, just to confirm, you may want to test whether other devices on the same network can detect each other to rule out a device-specific issue.
    On a separate note, I recently came across an interactive quiz format that people are using for engagement and testing purposes:
    Rice Purity Test
    Hope this helps Let me know if the issue persists.
    • rvtips's avatar
      rvtips
      Guide
      I can get to the site I just can't change the password?
    • StephenB's avatar
      plemans wrote:
      what is "my net worth"?
      I think "network"
