Xop0
Aug 20, 2023Star
Can not send sms with Netgear Nighthawk m6 6500
Does the device for 1000€ lack such a basic function that was in all previous m models? I can't send SMS either from the router, or from the application, or from the web panel. And without this functi...
Xop0
Aug 21, 2023Star
Can someone advise something? Or should I just return the router back to Amazon?
Is it possible to write an API to send SMS from a router if it does not have this function?
Traits from Netgear removed sending sms from m6 pro, although it was in m5, and my Bulgarian **bleep** operator requires sending sms every 10 gigs.
Moreover, from the operator's website you can send 20 sms per day, but only to long numbers.
Are there any ways to send SMS from a number that is not inserted into your phone, but on whose Wi-Fi you are sitting?
