www_985's avatar
www_985
cannot connect to aws, ftp
hi i have a nighthawk m1 mobile router.  i have my current ip address set up in aws with a new security group inbound rule, but it doesn't work...i cannot connect to the aws server.  i have the same exact setup for my dsl line ip address and it works fine.
i have default settings on the netgear router, nothing other than the att apn that i've added. any ideas why this won't connect to aws??
  • i think this might have to do with my ISP (at&t) blocking ports 5231 and 21, minimally. any insight here until i can confirm with them?
  • michaelkenward's avatar
    michaelkenward
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear routers covered in this section.
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
