Gr84caster
May 31, 2022Tutor
Cannot get my RBR850 to operate with my Nighthawk M6 Pro
I have an NetGear Nighthawk M6 pro 5G hotspot that is my only access to the internet. I have an ORBI RDR850 that I was able to use with my old 4G Nighthawk hotspot but when I hook up the rj45 cable ...
- May 31, 2022
Do you have the new router in passthrough mode or the orbi in access point mode? otherwise you're in a double nat
May 31, 2022Guru - Experienced User
Blanca_O
Jun 01, 2022NETGEAR Employee Retired
Hi Gr84caster
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR6500-1A1NAS)? This can be checked on the box of the product or on the barcode label
Kindly access M6 Web UI, go to General > Power Manager > change Power Manager Profile to Performance. Once done, check if you can go online wired to the M6.
Blanca
Community Team
