Gr84caster
May 31, 2022Tutor
Cannot get my RBR850 to operate with my Nighthawk M6 Pro
I have an NetGear Nighthawk M6 pro 5G hotspot that is my only access to the internet. I have an ORBI RDR850 that I was able to use with my old 4G Nighthawk hotspot but when I hook up the rj45 cable ...
- May 31, 2022
Do you have the new router in passthrough mode or the orbi in access point mode? otherwise you're in a double nat
May 31, 2022Guru - Experienced User
Gr84caster
Jun 02, 2022Tutor
Thanks. I changed the settings on the Orbi. It didn't work but I believe that there is an issue with the NightHawk as well. I'll post an update once NetGear gets the NightHawk working properly.
