john262
Dec 13, 2019Guide
Cannot logi in to LB1120 modem
Hi, I used to be able to log in to the LB1120's web GUI, but after a firmware update I can't log into it anymore. It says the password is wrong. I had previously changed the default passoword on the ...
Blanca_O
Dec 25, 2019NETGEAR Employee Retired
Hi john262
Welcome to NETGEAR Community!
How long did you hold the reset button? Please hold down the reset button until you see a change in the LED's status then let go.
Blanca
Community Team
john262
Dec 26, 2019Guide
Thank but I did follow that procedure.
