broof
Mar 17, 2019Aspirant
Cannot move files to SD card
I tried to enter the model with no luck? It is the Nighthawk MR1100. I cannot put any files on the SD card I put in the router from my computer ( this SD card did not say that it required a download...
PiD_Media
Mar 19, 2019Tutor
Is it the Telstra version of the M1 MR100 ?
I noted that the Tesltra firmware doesn't have the shared space allowed on the international version, so media files can be put on an USB or SD and then put in to the MR1100 for streaming to home entertainment,.. and no way to upload the files over the network.
- broofMar 20, 2019Aspirant
It is a MR1100-100 NAS purchased from DirectDial (recommended by Netgear). I do not believe it is “branded” with anyone but not sure?
I cannot create a new folder also ( message says an exception during request occurred)?
It starts to take a file, stops and try’s again and again until I cancel the request
(drag and drop).
The SD card is an SanDisk 32 GB. It did not say that it required a download on the package.
Thank You for your reply.
