lj99
Mar 09, 2022Aspirant
Cannot reset my Wireless Network password
For some reason, I can no longer reset my password under Setup/Wireless for either the 2.4 or 5GHz networks. I've done this at least 2 times before successfully. I've tried them individually, and tog...
Mar 09, 2022Guru - Experienced User
Also make sure you're meeting the password requirements.
At least 8 characters. I'd avoid special characters or spaces.
lj99
<<Also make sure you're meeting the password requirements.
At least 8 characters. I'd avoid special characters or spaces.>>
all letters & numbers only, already had 8 addedn 6 more with no change
