Lincon's avatar
Lincon
Follower
Jul 02, 2019
Can't acces to netgear aircard on my computer _ No ID
Hello everyone,,
I'm searching for the ID when the 810 is connecting by usb on the computer.
Can't find it. And it is not "admin"... or other number of the card ...
Can't someone help me please ?
Thanks
  • Hi Lincon ,
    The admin password should be located on the device label.  You will need to remove the battery to view the label.  The default password is usually admin or password.  If the password had been changed and you have forgotten then you will need to do a factory reset to set the password back to default.
    Arodi
    Community Team
1 Reply
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi Lincon ,
    Arodi
    Community Team
