DaCassilia06
Feb 22, 2021Aspirant
Can't Enable Wifi on ATT M1100
Hello Guys i Have bought two Att Nighthawk M1100-2A1NAS from ebay , one is working perfectly fine , but the other one only works thru ethernet or with USB C tether it always shows : Wifi Disabled ...
ArodiD
Feb 22, 2021NETGEAR Expert
Hi DaCassilia06 ,
Can you please PM a screenshot of the device label? You will need to remove the battery to see the label.
Arodi
