DaCassilia06
Feb 22, 2021Aspirant
Can't Enable Wifi on ATT M1100
Hello Guys i Have bought two Att Nighthawk M1100-2A1NAS from ebay , one is working perfectly fine , but the other one only works thru ethernet or with USB C tether it always shows : Wifi Disabled ...
Feb 22, 2021Guru - Experienced User
Have you checked to make sure IP-passthrough is disabled?
DaCassilia06
Feb 23, 2021Aspirant
I cant access to the portal , i think that he doesn't responds , for example when i want to reboot thru 192.168.1.1 it does absolutely nothing
