DaCassilia06
Feb 22, 2021Aspirant
Can't Enable Wifi on ATT M1100
Hello Guys i Have bought two Att Nighthawk M1100-2A1NAS from ebay , one is working perfectly fine , but the other one only works thru ethernet or with USB C tether it always shows : Wifi Disabled ...
Feb 22, 2021Guru - Experienced User
Have you checked to make sure IP-passthrough is disabled?
Mi9htyMarcu5
Aug 10, 2021Initiate
I have a nighthawk mr1100 and I can’t get it to work, I’ve been on the phone with att and I’ve been to their stores and they all tell me to use the app but without a internet connection I can’t use the app. I have a unlocked device and I’ve tried 2 different carriers in the last 2 weeks and still can’t get it to work. It say I have to finish setting it up to visit a website but all the websites they try to send me to crash and I can’t use them it also say I have to update my apn settings and I can’t do that either, that’s what I think the problem is but either way I can’t use my product and it’s disturbing. I am now at my home and I plugged my Ethernet cord from the wall into my hotspot to try to work it that way and still nothing
