AXRouterGuy1234
Jan 12, 2024Follower
Can;t Find Settings for AX5400 with MR1100 Nighthawk
Hello, amazing people! I am reaching out and hoping you can help. I am new to setting up Orbi's. We have the MR1100 Nighthawk by Netgear with ATT. However, every time I try to set up the AP sett...
CrimpOn
Jan 12, 2024Guru - Experienced User
The equipment description is a bit confusing. The Nighthawk MR1100 is a mobile LTE device:
https://www.netgear.com/images/datasheet/mobile/MR1100_100NAS.pdf
Perhaps it is being used as the Internet connection for an Orbi WiFi system? AX5400 is "Marketing Speak" for some imaginary number that comes from adding up several theoretical bandwidth numbers. What is useful is to know the specific model of Orbi that can be found on the product label on the bottom of the router.
Generally speaking, it is usually a good procedure to get the LTE device working first, before attempting to add the Orbi system.
