agdodge4x4
Mar 09, 2022Luminary
Can't get VPN to work on ASUS router with my MR1100...need setup help
I need to set up a VPN to my office. I have an ASUS RT-AX55 router and I went through the OpenVPN setup. I then Installed openVPN on on my iphone and imported the file. When I am IN my office connect...
Mar 09, 2022Guru - Experienced User
Is the MR1100 in passthrough mode?
Otherwise your in a double nat with runningt he mr1100 and the asus
agdodge4x4
Do you mean IP PASSTHROUGH?
IP PASSTHROUGH is DISABLED but VPN PASSTHROUGH is ENABLED.
- plemansMar 09, 2022Guru - Experienced User
try setting up ip passthrough on the MR1100
Or put your Asus's ip address into the MR1100's dmz.
- agdodge4x4Mar 10, 2022Luminary
IP PASSTHROUGH is turned on for the MR1100. Still no luck.
- plemansMar 10, 2022Guru - Experienced User
In ip passthrough, the netgear is acting as a pure modem. You'd want to check wtih asus after that on their vpn setup.
