ScottRMG
Jul 07, 2018Aspirant
Can't Remote connect to Nighthawk M1
Hi
Can't remote connect to Nighthawk M1 on Telstra network
The router advanced settings support Port Forwarding, which I have set up
But cannot conntect remotely either to current IP address, or via DDNS server (updates for DDNS server running off connected PC at 5 min intervals)
Please help :)
Thank you
- Blanca_ONETGEAR Employee Retired
Hi ScottRMG,
Can you ping the IP address or the DDNS server?
Blanca
Community Team
- ScottRMGAspirant
Hi
Thank you for your email
No I can’t ping either the ddns or the IP Address
Also had the same problem for my Nighthawk M1 from Telstra, need help, please.
