BillFromMD
Apr 20, 2020Guide
Can't setup AC1750 to work with MR1100
MODEM/ROUTER: Netgear MR 1100 cell hotspot ROUTER: Netgear AC 1750 (R6350) I am having ZERO luck setting up this router. I've been through the setup process half a dozen times with the Netge...
Apr 20, 2020Guru - Experienced User
Have you tried running the R6350 in access point mode? Leave the MR1100 running in router mode with the R6350 just controlling wireless and ethernet?
labatt
Apr 20, 2020Mentor
Besides the setting the router in AP mode, good suggestion, you might ask question on this forum as it supports you cell modem.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
