BillFromMD
Apr 20, 2020Guide
Can't setup AC1750 to work with MR1100
MODEM/ROUTER: Netgear MR 1100 cell hotspot ROUTER: Netgear AC 1750 (R6350) I am having ZERO luck setting up this router. I've been through the setup process half a dozen times with the Netge...
Apr 20, 2020Guru - Experienced User
Have you tried running the R6350 in access point mode? Leave the MR1100 running in router mode with the R6350 just controlling wireless and ethernet?
BillFromMD
Apr 20, 2020Guide
Not sure how to do that. Guess I've got some more research to do.
- labattApr 20, 2020Mentor
Go to this site and put in the router model. Will take you to a download section where you can download the user manual.
https://www.netgear.com/support/download/default.aspx
