BillFromMD
Apr 20, 2020Guide
Can't setup AC1750 to work with MR1100
MODEM/ROUTER: Netgear MR 1100 cell hotspot ROUTER: Netgear AC 1750 (R6350) I am having ZERO luck setting up this router. I've been through the setup process half a dozen times with the Netge...
BillFromMD
Apr 20, 2020Guide
I can't do access point mode because I still can't login to the router. I dragged the whole setup over to my Home PC and did Modem (MR1100) into Internet on the Router (AC1750-R6350) and that into and ethernet port on the PC and still nothing. The PC can see the ethernet conection, but says it has no internet. I found MAC addresses using a CMD line and still, Netgear Genie can't find the internet. Oh, and the Internet light STILL hasn't lit to even show me "yes, there's an ethernet cable but no, there's no internet". This is SOOOOO frustrating! You shouldn't need a degree in computer science AND electrical engineering AND experience as a network technician to install a simple router, especially when the modem and router are from the same company!!!!
labatt
Apr 20, 2020Mentor
Forget trying to use the apps. Not that great and not needed for most things.
Open a browser on PC or MAC connected by Ethernet and go to 192.168.1.1 or 192.168.0.1. Wireless is fine as well as long as you have a wireless connection to the router, but Ethernet is prefured. That should get you there for a login to the router. If not there are more basic problems. This does not require an Internet connection.
