Viper-666
Aug 30, 2025Aspirant
Cant update DC112A to latest Firmware
Hi, When I do a firmware check from within Netgear Genie it says it is the latest (V1.0.0.42_1.0.60) but when I check on the Netgear web site it says the latest is V1.0.0.62_1.0.60 which is 8 upda...
Viper-666
I know this has been asked before but I can't seem to find the answer.
I have several 810s mobile hot spots. I bought a DC112a to extend the signal & added an external aerial & all was fine for a while then all of a sudden no internet. When I looked at the 810s mobile signal strength & the was just a circle with a bar through it. I found if I took it out of the cradle the signal returned so I connected the aerial to the 810s then to the cradle via the USB & again this worked for a while but then did the same thing. Take it off the Air Card & it worked perfectly (Mostly)
I tried my spares & they all did the same thing. This is all post 2016 & I am sure all devices are the latest firmware. Upon checking 810 build date is Dec 2019 NTG9X40C_11.14.08.40 & I'm sure I updated the 112 too.
I couldn't get it to work so I bought another & without going into it the above happened to the new one.
As soon as any of my 3 or 4 810s are placed in the cradle the 810 loses signal.
Original it was just too boost the signal but I have a few spare old routers they can be configured into wifi extenders but they need to plug into a LAN point to do this.
Has anyone else sorted this out?
Cheers
