Viper-666
Aug 30, 2025Aspirant
Cant update DC112A to latest Firmware
Hi, When I do a firmware check from within Netgear Genie it says it is the latest (V1.0.0.42_1.0.60) but when I check on the Netgear web site it says the latest is V1.0.0.62_1.0.60 which is 8 upda...
CrimpOn
Aug 30, 2025Guru - Experienced User
After downloading the firmware zip file, do you extract the actual firmware image from the zip file?
- Viper-666Aug 31, 2025Aspirant
Yes but to be honest it was a long time ago. I stopped using it/them because of the signal fault but I want to start using the cradles again so I can set up some old router/modems I have that can be configured to be wifi extenders.
I'm no computer expert but I've built, programmed, networked computers/laptops etc. for years. Back when dial up was new.
That's not to say I don't make rookie mistakes. The above reply by myself case in point. That was suppose to be another question, don't know how I managed that.
Thanks CrimpOn
Any other ideas?
