sayed1997
Oct 27, 2017Tutor
Can't Update firmware of my Netgear MR1100
Hi there ..i got Unlocked Telstra Nighthawk M1 (MR1100) and currently it running under Sim card of Zain Kuwait ....my current Frimware is NTG9X50C_10.12.02.01 which is back on 2017/01/28 ...every ti...
anaspecial1
Feb 10, 2018Tutor
before i had the same problems but i change the sim card then i change the APN after that i can update it .
- tarkFeb 10, 2018Tutor
I am using my local provider sim card and their APN.
what have you done? and how
- anaspecial1Feb 10, 2018Tutori was using my local sim card but we had 3 deferent company’s i change from zain to mobily after that i add the mobily APN suddenly its work then i updated the firmware after that i returned my zian sim card and its work now
- imsarsehusFeb 11, 2018Starim also already updated, in malaysia got many telco and im try telco celcom but use another telco apn like..but it seem succesfull
- iieeannApr 30, 2018Aspirant
Thanks for the solution. I am from Malaysia with local simcard and unable to update the firmware, and no manul upgrade option available with existing old firmware. I just change the APN back to default telstra.internet, reboot the router and it can now detect the firmware upgrade.
