sayed1997
Oct 27, 2017Tutor
Can't Update firmware of my Netgear MR1100
Hi there ..i got Unlocked Telstra Nighthawk M1 (MR1100) and currently it running under Sim card of Zain Kuwait ....my current Frimware is NTG9X50C_10.12.02.01 which is back on 2017/01/28 ...every ti...
anaspecial1
Feb 10, 2018Tutor
before i had the same problems but i change the sim card then i change the APN after that i can update it .
tark
Feb 10, 2018Tutor
I am using my local provider sim card and their APN.
what have you done? and how
