sayed1997
Oct 27, 2017Tutor
Can't Update firmware of my Netgear MR1100
Hi there ..i got Unlocked Telstra Nighthawk M1 (MR1100) and currently it running under Sim card of Zain Kuwait ....my current Frimware is NTG9X50C_10.12.02.01 which is back on 2017/01/28 ...every ti...
tark
Feb 10, 2018Tutor
I am using my local provider sim card and their APN.
what have you done? and how
anaspecial1
Feb 10, 2018Tutor
i was using my local sim card but we had 3 deferent company’s i change from zain to mobily after that i add the mobily APN suddenly its work then i updated the firmware after that i returned my zian sim card and its work now
- imsarsehusFeb 11, 2018Starim also already updated, in malaysia got many telco and im try telco celcom but use another telco apn like..but it seem succesfull
