sayed1997
Oct 27, 2017Tutor
Can't Update firmware of my Netgear MR1100
Hi there ..i got Unlocked Telstra Nighthawk M1 (MR1100) and currently it running under Sim card of Zain Kuwait ....my current Frimware is NTG9X50C_10.12.02.01 which is back on 2017/01/28 ...every ti...
tark
Feb 09, 2018Tutor
hi all
anyone find the answer to this, i have the same problem but from UK
tsoetant
Apr 05, 2018NETGEAR Expert
Hi tark,
Could you please state the PRI version, FW version, IMEI? We can check whether the device contacted our Netgear server.
Thanks
- PepitoBirdApr 06, 2018Aspirant
Hi there,
I require the current firmware to resolve the issue with the ethernet port going to standby.
"Could you please state the PRI version, FW version, IMEI? We can check whether the device contacted our Netgear server."
I have sent you this in a private message.
- MAGADEApr 09, 2018Guide
Hi, guy, sorry for my english language but it is not my native language so...
May it possible to get some good news about the firmware upadte probleme.
I buyed a TESLTRA MR1100 laus desimlocked. It work properly but it is impossible to update it..
There is an executable version off firmware to got a general version like the MR1100 -EUS.
Or there is a trick to force the firmware update?
- MicWApr 11, 2018Luminary
Hi MAGADE
Updating the firmware via the built in update function of the M1100 is bugged for some people currently. tsoetant in a post above requested
some information to try and work out what is causing the issue. Netgear hasn't said if they are working on a fix for it yet, so I assume they haven't worked out the problem yet. There isn't any downloadable version available to manually update it yourself.
- PepitoBirdApr 19, 2018Aspirant
Pathetic support from Netgear.
Not even the courtesy to respond to my PM'd information that they requested.
