sayed1997
Oct 27, 2017Tutor
Can't Update firmware of my Netgear MR1100
Hi there ..i got Unlocked Telstra Nighthawk M1 (MR1100) and currently it running under Sim card of Zain Kuwait ....my current Frimware is NTG9X50C_10.12.02.01 which is back on 2017/01/28 ...every ti...
anaspecial1
Jan 16, 2018Tutor
salam alikom
do u got any ansowr can help
sayed1997
Apr 13, 2018Tutor
no i didn't yet .... and in future i'll not get any netgear because of this problem ...i can't understand why they don't want to give us an update
- JasonNApr 18, 2018NETGEAR Employee Retired
Hi Everyone,
I want to thank all of you for answering my PMs and working with me on this issue. :]
- Jason N
- JasonNApr 19, 2018NETGEAR Employee Retired
Hi PepitoBird,
I just PMed for further assistance. :]
I will be waiting for your response.
- Jason N
- MAGADEApr 19, 2018Guide
You are in good hand, Jason is very a good worker and helfull.
- PepitoBirdApr 19, 2018Aspirant
Done.
- JasonNApr 20, 2018NETGEAR Employee Retired
Hi PepitoBird,
Thank you for the PM. I have just replied to it. :]
- Jason N
- JasonNApr 23, 2018NETGEAR Employee Retired
Hi PepitoBird,
Thank you for confirming through PM that your issue has been fixed. :]
- Jason N
- windofageApr 24, 2018Initiate
I have the same problem.
PRI:01.16
Firmware:NTG9X50C_10.12.02.01When I clicked the "CHECK FOR UPDATES" button, it shown "CHECKING..." and nothing happens.
- JasonNApr 24, 2018NETGEAR Employee Retired
Hi windofage,
Refer to the link below to update your M1 Telstra to the current firmware.
Please let me know if this works. :]
https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
- Jason N
