sayed1997
Oct 27, 2017Tutor
Can't Update firmware of my Netgear MR1100
Hi there ..i got Unlocked Telstra Nighthawk M1 (MR1100) and currently it running under Sim card of Zain Kuwait ....my current Frimware is NTG9X50C_10.12.02.01 which is back on 2017/01/28 ...every ti...
windofage
Apr 24, 2018Initiate
Hi, JasonN,
It seems all 3 options doesn't work for me.
Option1: App gives me an error dialog after I click "CHECK FOR UPDATES"
Option2: There is no manual upload option cause my firmware is old.
Option3: The blue button freezes at "CHECKING..." after I click "CHECK FOR UPDATES".
JasonN
Apr 25, 2018NETGEAR Employee Retired
Hi windofage,
I will work with you through PM for further assistance. :]
- Jason N
- Mored1984Apr 26, 2018Tutor
Did U find solution for me.
Note:
Telecommunications company: Ooredoo
Model: MR1100
Firmware: NTG9XNTG9X50C_10.12.02.01
- JasonNApr 27, 2018NETGEAR Employee Retired
Hi Mored1984,
Have you done a factory reset and then tried "checking for update"? Have you reseat your SIM card?
Please let me know. :]
- Jason N
- Mored1984Apr 27, 2018Tutor
Already did four times but still can't update (Even can't manually update due not available "Choose file" button)
- Wesley_LianMay 16, 2018Aspirant
hello jason ,
i m from malaysia ...i also have a problem in upgrading the firmware...
even i follow some malaysia user which use celcom simcard with xox apn , still the same which cannot update the firmware...do you mind to help me update the firmware through the OTA...
i have attach together with the screenshot of my device info for you in order for the upgrading the firmware
- Jassem1988Jun 30, 2018AspirantHello
Here is my Netgear M1 info from the app
