sayed1997
Oct 27, 2017Tutor
Can't Update firmware of my Netgear MR1100
Hi there ..i got Unlocked Telstra Nighthawk M1 (MR1100) and currently it running under Sim card of Zain Kuwait ....my current Frimware is NTG9X50C_10.12.02.01 which is back on 2017/01/28 ...every ti...
anaspecial1
Feb 10, 2018Tutor
before i had the same problems but i change the sim card then i change the APN after that i can update it .
iieeann
Apr 30, 2018Aspirant
Thanks for the solution. I am from Malaysia with local simcard and unable to update the firmware, and no manul upgrade option available with existing old firmware. I just change the APN back to default telstra.internet, reboot the router and it can now detect the firmware upgrade.
