Hardwickp's avatar
Aug 29, 2022
Car charger for MR1100
What charger is recommended?
  • plemans's avatar
    Aug 29, 2022
    Theoretically, sure.
    But without one to actually test, all i can say is the specs match so it *should* work.
  • plemans's avatar
    The MR1100 uses a Quick Charge output that puts out 5v-12v for up to 15 watts. So just make sure it meets those specs and it should work.
    • Hardwickp's avatar
      Hardwickp
      Tutor
      Thanks- would this be OK?
      Car Charger for Samsung,30W Fast Quick Charge 3.0 Car Charger Cigarette Lighter with Cable for Samsung Galaxy S10 S9 Plus A51 A52 A52S 5G A50 A42 A13 A33 A12 A40 A70 A20E,Xiaomi Redmi Note 11 10 9 Pro https://amzn.eu/d/aUEfTe6
      • plemans's avatar
