in2ndo
May 18, 2018Apprentice
Car charging or hot-wiring of Nighthawk MR1100
Hi All.
Anyone knows what car charger I can use for the Nigthawk hotspot MR1100 or the set up to hard-wire it to the car so that is always on.
TIA.
in2ndo
Thanks for the replies.
Since the hotspot is going to be mostly in my truck. Providing WiFi access to a couple of dashcams 24 hours a day. I’m looking into this.
https://www.blackvue.com/power-magic-pro/
Hopefully someone here is familiar with it or the possible technical involvement running this set up.
I have asked blackvue. But since they make it specifically to power their dash cams. They won’t say either way to power something else.
The lower on this things can be adjusted and the main part. Is that it will shut off the current to the hotspot if the trucks battery is getting to low.
All opinions welcome.
Thanks again.
Thanks again.
n3t
May 19, 2018Apprentice
Well, according to the product information on the web page you linked to, the Power Magic Pro does not actually "power" the devices connected to it — it is just a programmable switch that is placed between the car battery and consumers which should be kept operating even after the engine is turned off, to protect against depleting the car battery to a degree where you wouldn't be able to start the engine from it anymore.
I.e. what you connect to the "back side" of the Power Magic Pro is still powered from the battery and with exactly the same voltage that the battery provides. So of course should you be able to connect a QuickCharge capable USB car charger there alongside the cameras.
