in2ndo
May 18, 2018Apprentice
Car charging or hot-wiring of Nighthawk MR1100
Hi All.
Anyone knows what car charger I can use for the Nigthawk hotspot MR1100 or the set up to hard-wire it to the car so that is always on.
TIA.
TechCure
Sep 27, 2018Aspirant
You could take the battery out. Then, plug it into any usb car charger without a battery. It will work. Keep the charged battery seperate for use when not plugged in.
