knightmare
Jul 24, 2020Tutor
cax80 vx CM1000/CM1100/CM1200 -> ORBI
I'm looking to convert from ATT to SPECTRUM and get my own Cable modem. I currently have a PACE 5268AC. The modem connection is upstairs and I have dead zones downstairs. Upstairs is about 1100 s...
- Jul 24, 2020I've actually left the wifi on my CAX80 running. it allows me to test/play with AX devices. I just make sure the wireless channels are separate from what my orbi is using. And I have the orbi in access point mode. This keeps it simple since I'm only using the orbi for wifi. I do the rest of the management with the CAX80
knightmare
Jul 24, 2020Tutor
plemansthanks for the info. So if I understand the main PC is connected directly to the CAX80 to take advantage of a wider pipe. I assume you then disable the WIFI on the CAX80 and just use the RBK50 as the WIFI router. If so then it sounds like I could then have a CAX80 as the modem, turn off WIFI and DHCP, use the 2.5 ethernet to connect to the NAS device(or try aggregate to see how well it works), connect the RBK50 as the WIFI router and set up 2 satellites downstairs. Also then I could reserve IP's for the other hard wired devices using the ports on the CAX 80 (or switch if needed), and then use the ORBI strictly for WIFI on the same subnet and have it do the DHCP for a range of ip's not in use by the CAX80. Sounds like the RBK53 system might be a good starting point to see if it will give the desired range in the yard.
The tip on the CAT5 sounds real interesting. I'll have to check that out.
Jul 24, 2020Guru - Experienced User
- knightmareJul 24, 2020TutorThanks for all the help/info. I'll try the cax80-->rbk53 approach and see if that works.. Seems like it should..
