LeifA's avatar
LeifA
Apprentice
Aug 14, 2019
Change Gateway address M1
Hi!
When I change the gateway on my M1 to 192.168.1.2 I loose connection.
The browsers say "too many redirects" and I have to reset the M1 to factory settyings.
It is a bug or is there a way to et another gateway address?
I tried different browsers on different units, cleared cookies, caches etc.
Make yourself a nice day!
Leif
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi LeifA
    Welcome to NETGEAR Community!
    What was the IP address of the devices you used to access MR1100 settings page?
    For isolation, can you please input another IP address to check if you still get the same message?
    Please describe your network setup. Why need to change the Gateway IP to 192.168.1.2?
    Blanca
    Community Team
