hdc101
Aug 28, 2020Aspirant
Changing IP address on Nighthawk M1 Router
I would like to change the range of IP addresses that this router assigns. Currently, when connecting I recive an ip address in the 192.168.x.x via DHCP I would like to change it to an adress out of ...
Ksa3344
Aug 31, 2020Apprentice
from the web page go to
settings - mobile router setup
chang the Getaway ip address , the starting ip address and ending ip address.
When you do that apply the changes and you may lose access to the settings through the app but you will still have access from the web page through the new Getaway ip .
- hdc101Sep 02, 2020Aspirant
Whenever I change those settings I get an error saying that I need to use an adress in the DHCP range. Is there a way to fix this?
- Ksa3344Sep 02, 2020Apprentice192.168.x.1
Just change the x value to another number for example make it 2 or 10 and make sure its the same in getaway ip , starting ip and ending ip .
