hdc101
Aug 28, 2020Aspirant
Changing IP address on Nighthawk M1 Router
I would like to change the range of IP addresses that this router assigns. Currently, when connecting I recive an ip address in the 192.168.x.x via DHCP I would like to change it to an adress out of ...
hdc101
Sep 02, 2020Aspirant
Whenever I change those settings I get an error saying that I need to use an adress in the DHCP range. Is there a way to fix this?
Ksa3344
Sep 02, 2020Apprentice
192.168.x.1
Just change the x value to another number for example make it 2 or 10 and make sure its the same in getaway ip , starting ip and ending ip .
