simoncoops
Mar 24, 2023Aspirant
Charging issues Nighthawk M60 Pro (unlocked)
I am having issues with my new Nighthawk M6 Pro mobile hotspot (unlocked). Using the factory USB-C to USB-A cable and power brick in the mains seems to take so long to charge. I am basically pluggi...
michaelkenward
Mar 24, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- simoncoopsMar 24, 2023AspirantMany thanks for your response and help to love my subject.
