Dreamcaster51
Jan 03, 2017Aspirant
Charging problems with 790s
After searching various forums I found that many other people have the same problems as I have with my 790s, that is charging the little blighter. I have to hold the cord at 'such an such' an angle t...
DarrenM
Jan 10, 2017Sr. NETGEAR Moderator
Hello Dreamcaster51
I would contact you ISP for support on this.
DarrenM
- Dreamcaster51Jan 10, 2017Aspirant
Hi DarrenM
I have contacted the mob I purchased it from over the internet and got no where. I visited a store in a small town up the road and was being helped for a while
then it got too hard for them. Every one wants to blame the other guy, eventually after saying I would take it to Consumer Affairs (in Australia) things started to change. They
wanted proof of purchase but as I said I purchased it from them over their help line because an eairlier modle stuffed up, so I was unable to show proof of purchase & it was too hard for them to look it up..
Any how I ended up getting a second hand ( almost new) 810S aircard which has a much better charging plug. After the dust settled the guys admitted they have
had heaps of trouble with the same fault on the 790s. If it is known why not a recall?
Never mind ended all good , thanks for the reply
Dreamcaster51
