BAD240Z
Apr 05, 2022Follower
Check for LTE UPDATES fails
From the Router App - Router Settings - Router Information At the bottom of the screen you have 2 options 1. Check for UPDATES = Which it performs OK 2. Check for LTE UPDATES = FAILS with the messa...
Apr 05, 2022Guru - Experienced User
what device do you have?
And what firmware version are you on?
Have you checked the support site for updates to the firmware?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
