YankeeDude's avatar
Sep 10, 2019
Chromecast cannot connect to Nighthawk M1
New installation of Chromecast (generation 3) cannot connect to Nighthawk M1 (Firmware: NTG9X50C_12.06.03.00). QUESTION: How do I disable Access Point/AP isolation in the Nighthawk M1? My answer...
  • YankeeDude's avatar
    YankeeDude
    Sep 18, 2019
    Problem solved. :smileyhappy: And it was so much simpler than I could have imagined. After trying "just about everything" I finally did what should have been the obvious FIRST thing to do: perform a factory reset of Chromecast.
    Summary: the problem lies entirely with Google Chromecast.
    After configuring Chromecast to a specific Wi-Fi network, the unit is "locked" to that network. Of course this is a feature that helps when restarting Chromecast. However, when changing networks, it is a problem.
    Solution: FORGET NETWORK before trying to connect to a new network. Or perform a FACTORY RESET.
    SOLUTION LINKS – GOOGLE CHROMECAST HELP:
    • Change the Wi-Fi network of Chromecast
    • How to factory reset your Chromecast
    VIDEO EXPLANATION - YOUTUBE
    • Google Chromecast 3rd Gen: How to Factory Reset
