Prunella
Jul 08, 2022Aspirant
Circle with line going through
I have a circle with a line going through it could anyone give me a clue to what it means please
Jul 08, 2022Guru - Experienced User
Not much to go off.
Is there a screen capture of what your seeing?
Is this in regards to a NG product? If so, what model # product do you have?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
- PrunellaJul 09, 2022AspirantThanks for replying its a netgear MR21000 mobile router, there is a small circle with a diagonal line going through it as if it is a no entry đ« it's in grey though thanks
- FURRYe38Jul 09, 2022Guru - Experienced User
I would refer to the user manual for all information regarding this model router.
