VincentPhan
Jan 21, 2018Aspirant
CM500 connects only 100mb to PC or Netgear router.
I have a CM500 modem for home with Comcast and speed 100down/5up and had been happy with it for 3 months now. Comcast upped it to 150down now and it's all fine. Use R8000 behind it. Bought a second...
TheEther
Jan 21, 2018Guru
A bad Ethernet cable can cause this.
- VincentPhanJan 23, 2018Aspirant
Sure.
Three separate cables used, two brand new from the boxes of the units and one connected Gigabit earlier.
- TheEtherJan 23, 2018GuruIt's rare but occasionally two devices can fail to negotiate to run at 1 Gbps. Netgear doesn't provide any user settings to control this. I've seen people successfully use an Ethernet switch in between. Normally, you should never put a switch between a modem and router, but this is one exception.
Seeing as you returned everything, I would not worry about this happening again. As I said, it's rare for this to happen.
