akernell
Nov 11, 2020Follower
Code 3
Hi everyone, My MR1100 keeps shutting off on its own and now every time I try to turn it on, I get the error, "Code 3 Remove Battery and USB". Does anyone know how to fix this?
Nov 11, 2020Guru - Experienced User
If you remove the battery and just have it powered from the usb, does it work?
Lrichard
Feb 10, 2021Aspirant
Bonjour,
On the screen of the router I have the error message : 'code 3 remove battery and USB'
If I take off the battery and plug the USB cable only it works.
What's wrong and what should I do
Thanks
Richard
- Blanca_OFeb 10, 2021NETGEAR Employee Retired
Hi Lrichard
Welcome to NETGEAR Community!
Please provide the device SKU (e.g. MR1100-100NAS) and firmware version.
Blanca
Community Team- MarksmithwickMay 03, 2021AspirantSKU 6420B
I have the same problem I bought a new battery exact replacement and now I get a code 3 It works fine with the old battery but the old battery started to swell please let me know what I can do to fix this - MarksmithwickMay 03, 2021AspirantSKU 6420B Model MR 1100
