akernell
Nov 11, 2020Follower
Code 3
Hi everyone, My MR1100 keeps shutting off on its own and now every time I try to turn it on, I get the error, "Code 3 Remove Battery and USB". Does anyone know how to fix this?
Lrichard
Feb 10, 2021Aspirant
Bonjour Blanca,
Thank you for the answer.
SKU is MR1100-1TLAUS
firmware version is NTG9X50C_12.06.08.00.
Waiting from you
Best regards
Richard
- Blanca_OFeb 14, 2021NETGEAR Employee Retired
- LrichardFeb 14, 2021Aspirant
I can't find your message
- michaelkenwardFeb 15, 2021Guru - Experienced User
Get at Private messages by clicking the "envelope" icon at the top.
Private messages
- 2goodMay 14, 2021AspirantNighthawk MR1100
Keeps getting code 3 remove battery and USB ??
Is there a fix for this ? - JiveeJan 23, 2022AspirantPlease share this solution or explanation to the other people with this problem. Thank you.
- JohnPengJan 23, 2022NETGEAR Expert
Code 3 means the battery is not compatible with the device. If you would like to replace the M1 battery, please visit the link below. Some batteries sold on ebay or amazon are not compitable even though they have the same rating.
https://www.netgear.com/home/mobile-wifi/hotspots/mhbtr10/
It is out of stock right now. Will be restocked soon.
Thanks
