akernell
Nov 11, 2020Follower
Code 3
Hi everyone, My MR1100 keeps shutting off on its own and now every time I try to turn it on, I get the error, "Code 3 Remove Battery and USB". Does anyone know how to fix this?
carolcooney
Aug 22, 2021Aspirant
Mine is doing this too. Did you figure out how to fix it?
- NickHarderAug 26, 2021AspirantHas anyone gotten a fix for this. Mine just started doing it randomly and now won’t go away.
- MikespeersDec 09, 2021Aspirant
Hi, I have the same error code (3) when I installed a new battery. It works fine on usb. I see other people have had the same issue, can anyone help me please?
- King08Feb 09, 2022Aspirant
Mine is that, I only get code 3 when I need to charge its battery, which means I couldn't charge it and has to remove the battery according to its instruction; however, not at all times, removing really works. So, for it to work continuesly, I got to remove the battery first then plug the usb. Once the device is powered up, that's the only time i put its battery back in. This work perfectly to me.
