akernell
Nov 11, 2020Follower
Code 3
Hi everyone, My MR1100 keeps shutting off on its own and now every time I try to turn it on, I get the error, "Code 3 Remove Battery and USB". Does anyone know how to fix this?
NickHarder
Aug 26, 2021Aspirant
Has anyone gotten a fix for this. Mine just started doing it randomly and now won’t go away.
King08
Feb 09, 2022Aspirant
Mine is that, I only get code 3 when I need to charge its battery, which means I couldn't charge it and has to remove the battery according to its instruction; however, not at all times, removing really works. So, for it to work continuesly, I got to remove the battery first then plug the usb. Once the device is powered up, that's the only time i put its battery back in. This work perfectly to me.
